Alternative for the Quotient and Remainder function inside an SCTL
Hi NI community,
I recently started working with LabView and am trying to design a switch port selector algorithm for an FPGA. This includes a counter with a total number of repetitions (e.g. 100) which needs to switch on every Nth (e.g. every second) repetition.
To implement this, I used the Quotient and Remainder operation after the counter, placed within an FPGA source clocked Single-Cycle Timed Loop (SCTL). Since this function is restricted to use in a SCTL, I am trying to find an alternative which won't influence the outcome. Any advice is highly appreciated.
Thanks!
(3,387 Views)
Keep the counter in a shift register.  It increments every iteration.  When the value reaches your desired count (what you were trying to divide by), reset using the Select node (current count in FALSE, 0 in TRUE).
(3,358 Views)
