Am I able to tag a data point of a spreadsheet that is being created by a datalogging VI such that at the end I have the data with multiple tags which corelate to events during a measurement cycle
My final need is to take data from a datalogging VI and store it in a spreadsheet with tags that corespond to events in a subVI which is controlling motor movement. This will allow users to view all data and mark the relevent data for analysis. As usual, user want everthing but with conditions.
(2,490 Views)
Sure. What you do is take the numeric value acquired, the tags you want, and build them into an array. So now, when you write to the spreadsheet, you'll have a 2D array. One thing you have to keep in mind is that all elements of an array have to be of the same type. So if your tags are strings, you'll have to convert your numeric data into strings as well.
(2,490 Views)
