Amazing! LabVIEW 8.5 FPGA Fifos are never full!
All joking aside, what happened to the FIFO full terminal found when attempting to Write to a FPGA FIFO in 8.2?
LabVIEW 8.5 seems to remove this feature. I checked the error code too and it doesn't output an error if FIFO is full. Is there another way to check this other than assuming the fifo is full when the FIFO Write timeout?
Craig
(3,029 Views)
Hi craige,
The "Full" output of the FIFO Write in FPGA Module 8.2 has the same function as the "Timed Out?" output in 8.5.  The Help file descriptions of the two outputs in the two different versions are the same.
James R.
(2,959 Views)
