Amplifier in PCI-6143? Different ranges?
I have a PCI-6143 and the input range are AI ±5V. Are there any other voltage ranges that I can set in the hardware?
I have searched the manual but cannot find any information about it. I remember that I read something about lower ranges but I don't know where. Can someone help me out?
If not, I need to build external amplifiers.
(2,634 Views)
Accepted by topic author Haddock01
Hi Haddock,
I don't know what you read, but the PCI-6143 manual is pretty clear:
Just one input range.
You can set other (smaller) ranges in DAQmxCreateChannel, but the hardware will only use this one range…
(2,619 Views)
Yeap. You confirm what I suspected and also read. When I saw the block diagram and noticed the amplifiers each channel had I hoped they were configurable.
If I need a lower range then I can use the 5V range anyway. The resolution is sufficient for the task. I just change the Y-scale min/max.
(2,605 Views)
