Amplitude measurements of peaks
How do you measure the amplitude of individual peaks in LabView?
(3,011 Views)
The VI shown in the attachment will give peak location and amplitude, but often it gives the wrong amplitude.  I usually just take the location that it gives and find the amplitude of the location in the array.
Jim
LV 2020
(3,003 Views)
I've tried using this vi and others (see attached along with data) and they all give me conflicting/wrong results.  I want to measure the amplitude of a series of peaks, where the amplitude for each peak is different.
(2,989 Views)
You need to give the peak detect a width and threshold.  Try 10 and 1.5 respectively.
Jim
LV 2020
(2,977 Views)
Correction.  Smiley Surprised  Try width of 30, threshold of 2.
Jim
LV 2020
(2,958 Views)
The same as you do with every other tool (including pen and paper), using math.
André (CLA, CLED)
(2,945 Views)
Thanks for the help lmtis, much appreciated.
(2,925 Views)
