Amplitude of One Part of a Signal
Hello!
I managed to find amplitude of the whole signal saved as spreadsheet using Amplitude and Levels.vi. It works great. How can I find amplitude of one part of the signal (let`s say first 10% or 0.0001 seconds)? In a word, how do I set up time limits for that VI?
Thanks for your help.
(2,901 Views)
@Ivan899 wrote:
Hello!
What do you mean 10% or 0.0001 seconds, I don't understand. Are you acquiring data at more than 10KHz? If possible please attach the code.
(2,899 Views)
Thanks for your quick reply.
I`ve attached VI and two spreadsheets. Initially two waveforms have just noisy components and I need to find out amplitude of this noise for further utilization its value for threshold settings. I want to make threshold dynamic depending on the level of noise amplitude. Currently I am able just to find amplitude of the whole signal including peaks using Amplitude and Levels.vi.
(2,890 Views)
Accepted by topic author Ivan899
Judging by your code you seem to have a good grasp of waveform manipulation.  You can use the Get Wfm Subset VI (Waveform palette) or just roll your own subset grabber with the tools in the Array palette.  The Get Wfm Subset has the advantage of calculating the time based on the dt.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,886 Views)
Great! I think this is exactly what I needed. Thank you very much!
(2,877 Views)
