An array to tomographic or tomography image
Hi , I have an array 20*20 which has different RSS value from 20 wifi sensors and i need to covert this array into an image show the different between each matrix i have so it will become similar to this.. sample matrixsample matrixc63626ad-20a4-41d9-91ca-8b7af719a9e8.jpgc63626ad-20a4-41d9-91ca-8b7af719a9e8.jpg
(2,866 Views)
If you want a 3D contour plot.... why don't you use the 3D contour graph indicator??  GRAPH > 3D Graph > Contour
(2,827 Views)
You might want to interpolate those values to get a smoother look...
(2,799 Views)
