An code -18001
Hello Everyone,
I am using TestStand 4.0 and LabVIEW 8.5.1. I developed the LabVIEW test code module to test the DUT and integrated those modules in TestStand. I created the TestStand build and installed in PC which is not having the NI components.
The following are the error what I faced while running the test sequence
I am running a deployment version of TestStand with our own customizable operator interface. When I execute the test sequence the OI pop up's an error as follows: "An error occured accessing the LabVIEW ActiveX automation server.[Error code: -18001]. This PC contains only the TestStand Run time. The above error is not coming when I install the LabVIEW in that running PC.
Please advice.
(3,619 Views)
Is the LabVIEW runtime installed? Do you have the LabVIEW adapter set to use the runtime?
(3,613 Views)
Yes, LabVIEW runtime engine also installed. I created the TestStand build by setting the TestStand adapter to "LabVIEW Runtime Mode".
That error is not coming when i install the LabVIEW development version.
(3,600 Views)
