An error occured-The NI System Web Server is not running
1.go to window and type services
2.open services
3. search NI System Web Server from the list.
4.then right click on it and press start.
5.if problem persists the find NI Service Locator from the same list
6.Right click on it and click propoties.
7.choose Startup Type as Automatic and click ok button
8 again follow step3 and 4.
9.Then all you get Problem solved
A Programmer:Bhanu Pratap Behera
Technical Assistant
NIT Rourkela
Message 21 of 22
(2,955 Views)
Thank you Bhanu,
you additional step looks like it has solved my problem..
Cheers
Alex
Message 22 of 22
(2,628 Views)
