An error occured with Labview 5.1.1 and Netscape 7.1
After upgrading Netscape from version 7.02 to 7.1 i receive miscellaneous errors after some time while executing an program which sends and receives data via tcp/ip. If an error has occured, it is necessary to restart Labview and Netscape. Then it works some hours before crashing again. With Netscape 7.02 everything worked fine.
Any solutions?
(2,912 Views)
Are you using LabVIEW and Netscape together, or do they happen to be running at the same time? What if one of them is not running?
It sounds like maybe Netscape 7.1 replaced the tcp/ip stack, or did something similar (are you running an older OS?).
Have you watch the memory usage of LabVIEW and/or Netscape to see if maybe resources are not being freed?
(2,912 Views)
Normaly, Netscape (only the Messenger) is running all the time. And some time the Labview-program which uses tcp/ip is running at the same time. This does not make any trouble. But if I am using the Netscape Browser too at the same time, then miscellaneous errors occur and I must restart the whole Netscape suite. If I don't do this, the Labview program always reports an error.
Little time before Labview reports an error, the Browser view in Netscape is corrupted (some times arabien characters).
I am using Windows 98SE. With Netscape 7.02 everything worked fine, the error occured after upgrading to version 7.1.
I haven't looked at the resources yet, but I will do.
EPH
(2,912 Views)
