An error occurred attempting to connect to this compile server.
Hi all,
I am running a VI on FPGA in CRIO-9045.
However,I encountered the error below
Details:
NI-Farm: Farm server is not responding. Be sure the specified hostname is correct, the server is running and configured to accept remote requests.
Please see the attached file for the detail. Thank you very much.
(2,908 Views)
Hi rt,
unfortunately you hide the details in the "Select Compile Server" dialog…
But it seems you selected the local compiler server: is the compiler toolchain installed on your local computer?
(2,900 Views)
Hi GerdW,
Yes, I selected the local compiler server.
I am not sure what do you mean compiler toolchain. The installed software in my local computer related to compiler is attached in the file.
Rudy
(2,844 Views)
Hi Rudy,
is it just this project - or does any FPGA project give the same error?
Did you create a BuildSpec for your VI?
(2,832 Views)
