An error occurred on the server. Would you like to try again?
Hi, I have a problem.
I wanted to register my product and get an error message.
Click Yes to retry adding new serial numbers. Click No to discard new serial numbers. If the problem Persists, contact National Instruments technical support at ni.com / support.
I am from Germany.
E-mail:jgk1991@googlemail.com
(2,970 Views)
What are you trying to register? Hardware?
Please contact your local NI branch for support in such cases. You can find directions on this in the link "Contact NI" you can find next to "MyNI" in the top bar.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,963 Views)
