An error occurred on the server. Would you like to try again?Click Yes to retry adding new serial numbers.
I have a problem:
when I´m trying to add the Serial Number, to register LabVIEW, following error message occurs:
"An error occurred on the server. Would you like to try again?Click Yes to retry adding new serial numbers. Click No to discard new serial numbers. If the problem Persists, contact National Instruments technical support at ni.com / support."
I would appreciate your help/advice.
(2,816 Views)
Please contact your local NI branch for support in such cases. You can find directions on this in the link "Contact NI" you can find next to "MyNI" in the top bar.
Hope this helps,
Mathan
(2,805 Views)
