An error occurred trying to load the assembly labview 2020
I am trying to connect Kinesis to Labview following these instructions: https://www.thorlabs.com/Software/Motion%20Control/Kinesis/Kinesis-labview.pdf
The .net container keeps showing an error message when I try to pull up the kinesis program. I have tried these solutions, but they seem to not work:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XnSAK&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFdZSAU&l=en-US
Does anyone know how I can get rid of the error message and actually have Labview pull up the controls?
(3,742 Views)
Accepted by topic author miataylor1231
Did you install the correct "bitness" of Kinesis?  If your LabVIEW is 32-bit, you need to install the "Kinesis 32-bit for 64-bit computers" version.
It's also best if you try it with a VI that is in a project file, and that project file is in a directory with all 100+ DLLs that come with the Kinesis driver.
I can verify that LabVIEW 2018 works with the DLLs in this situation with the 1.14.9 DLLs.  Anything newer I haven't tried.
(3,740 Views)
Ah! I just checked Kinesis and it is 64-bit while Labview is 32-bit, thank you so much!
(3,737 Views)
