An error occurs when opening the Channel Config.xml file.
Validation failed on: C:\Program Files (x86)\National Instruments\LabVIEW 2020\examples\Astronics Ballard Technology\BTI429Lib\Example 01-Receive Labels\Example 01-Receive Labels\Channel Config.xml
Reason:
According to DTD/Schema
The property'{http://www.w3.org/2001/XMLSchema-instance}schemaLocation' has an invalid value.
Source:
<channel429 ID='1' name="Mychannel1"
xmlns="http://www.ballardtech.com/DatabusSchemas/"
xmlnsxsi="http://www.w3.org/2001/XMLSchema-instance"
xsi.schemaLocation="./bti.xsd">
Line:
2
(1,749 Views)
I got open the website "https://www.w3.org/2001/XMLSchema-instance%7DschemaLocation"
It returns Error 404 - Not found (w3.org)
Maybe it's the issue.
(1,649 Views)
I can open that website:
But it says you should never use it…
(1,645 Views)
Maybe you better not used the link.
Seems like only authorised user can log in the link, privacy issues.
(1,642 Views)
