An event structure can freeze the front panel even if not executed?
See example (LV9). Two Event structures, each in a case of a Case structure; if they handle the same event, when it fires the front panel freezes.
Message 1 of 9
(5,377 Views)
can you save it as a 8.6 so I can open it?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 9
(5,374 Views)
I suggest you read the caveats of using the Event structure in the LV help.  The case structure does not stop execution of the event structure so you effectively have two event structures in the same loop.
Message 3 of 9
(5,372 Views)
As Darin already stated, this is expected behavior and a wellknown DO NOT for event structures.
So please make it a rule of thumb:
Never ever configure two different event structures to fire on the same eventsources!
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 4 of 9
(5,366 Views)
Good to know. It's not written in the Caveats page
Message 5 of 9
(5,343 Views)
Yes it is. It's called 'Avoid placing two Event Structures in one loop.'
Message 6 of 9
(5,339 Views)
I know, but it talks about two Event structures executing in parallel (and that's logic).
It does not say they will magically wait for events even if they don't execute...
Message 7 of 9
(5,331 Views)
What you have to understand is that an event structure is always waiting for an event and that placing one inside a case statement does not mean it will not capture events. Two event structures in the while is still two event structures and the case statement does not change that.
Message 8 of 9
(5,323 Views)
I already understood, thanks.
Just saying it's not written in the help, that's it.
Bye
Message 9 of 9
(5,318 Views)
