01-22-2006 08:39 PM
01-23-2006 09:59 AM
01-24-2006 09:22 PM
01-24-2006 10:35 PM
Hi David,
Yes, you can customize the positions of splitters, and as a result, control the size of the panes on your front panel. Here are some of the different properties you can change on a splitter bar:
There are also several properties of the Pane class that relate to the panes on either side of a splitter. Let me know if you'd like more information about those (although I suppose you could look for yourself at the LabVIEW 8.0 Evaluation version).
Good luck,
-D
01-25-2006 08:47 AM
