Analog Input of 6008 DAQ Device
I have created a program that uses an analog out and analog in channels of the 6008 DAQ device. I am having trouble with reading voltage through the analog input channel through an executable. When I try to run an executable of the program that I wrote, it is not reading the input voltage being sent from a voltage source through the DAQ device. However, when I run the source code, it has no problem reading the voltage. Why is there a discrepancy between running from the source code and running from an executable? Thanks in advance.
(3,101 Views)
I did forget to mention that when I try to run the executable, the analog out channel outputs correctly. The analog in channel is the one that does not work during the run of an executable.
(3,085 Views)
primesh,
please see here for a solution.
hope this helps
(3,081 Views)
Thanks for the help. The modification to the vi setting corrected the problem.
(3,058 Views)
