Analog Input
I am trying to read analog input and am looking at Trigger Multiple Channels With Individual Trigger Conditions - NI . In the "Using Labview FPGA" example, they seem to streamline reading from a channel while using some of these:
I am looking to see what those (highlighted) are called so I can use them in my own code.
Thank you!
(1,362 Views)
Hi Squirrel,
These are IO nodes from an AI module…
(1,347 Views)
Accepted by topic author SuperFastSquirrel
@GerdW wrote:
Hi Squirrel,
Those IO nodes are only there when using the Scan Engine on a cRIO or PXI FPGA instead of programming the FPGA.
(1,338 Views)
