Analog Output Voltages not mirroring the LabView function output
Equipment:
    NI 9189 cDAQ
    NI 9209 Analog Input Module
    NI 9264 Analog Output Module
Issue:
    When running our program (attached zip folder, program is labeled Dyno Main Program) to a USB X Series multifunction DAQ the excitation values matched the voltages produced by the module. We have moved our setup over to the more complicated system above since it matches our final desire more appropriately. However, the program is not producing the proper voltages in the analog output module. Testing the module with a multimeter output voltages are correct until they stop between 3.3 and 4.3 based upon the pin we are choosing to use. We would like to run them with excitation voltages up to 10. When running a test through the NI max the module correctly producing values to the +-10V the module can handle and this leads me to believe it may be a problem with our code. Any help would be greatly appreciated.
(1,907 Views)
Accepted by topic author Mrhighsky40
Ignore the post; when I came back after lunch this problem didn't occur anymore. Most likely just user error on my part!
(1,895 Views)
