Analog Output lag time? Newbie question.
Hello all,
I am writing a very basic program to provide an output voltage between -10 and 10 volts from an Omega brand DAQ. I am using the ULx for Labview .vi library that came with the DAQ. Currently the program is working, giving me the requested output voltage while it runs and 0 once I end the loop.
However, when I initially click run, it takes 15-20 seconds for the program to pass beyond the "create channel" .vi at the beginning. I used the "highlight execution" tool to observe this. I was wondering if I've done something boneheaded to cause this delay or if it is unavoidable.
I attached a screenshot of my program. Please feel free to offer any other advice you have!
Thanks for the help,
-Bryan
(926 Views)
Accepted by topic author Bryan7
Hi Bryan,
There's nothing you can do inside of LabVIEW: when this function needs that time to load all the ULx stuff in the background then you need to wait for it.
Does it take so long every time you run the VI?
(904 Views)
Hey GerdW,
Thanks for the help! I found a tip on the ULx forums about the load times for the library and fixed it by changing the file locations. It runs smoothly now!
(888 Views)
@Bryan7 wrote:
Hey GerdW,
So what was the solution? Where did you move them? And what did you move?
Qestit Systems
Certified-LabVIEW-Developer
(844 Views)
I referenced this thread: https://forum.digilent.com/topic/24259-question-about-downloading-and-opening-ulx-with-labview/
Hope posting that link is ok? Changing the files from read-only may also have been the factor that increased my speed.
Cheers!
(822 Views)
