Analog Output with NI 9264
I'm trying to set up a simple analog output through the DAQ assistant and i'm not getting anywhere with the forums or example.
2 slider outputs sending 0-5V through a NI 9264 Analog Output module. Seems like it should be pretty straight forward but it isnt.
Help?
Message 1 of 10
(5,247 Views)
Unfortunately a lot is hidden when you use express VIs and dynamic data. If you configured it for multiple samples it's going to expect 1 array per channel. I would just stick to the DAQmx VIs and it looks like this:
Or, with multiple channels it would like this:
Message 2 of 10
(5,230 Views)
I was hoping to do it with the DAQ assistant, as I am new to lab view
Message 3 of 10
(5,226 Views)
I see, well the pictures I uploaded are snippets, so if you have LV 2016 or above you can drag them onto your block diagram and it becomes code you can run, doesn't get much easier than that! I'll attach a VI as well if you need it.
Message 4 of 10
(5,221 Views)
I'm running 2015 I believe
Message 5 of 10
(5,219 Views)
I can't open the vi you shared
Message 6 of 10
(5,202 Views)
Message 7 of 10
(5,194 Views)
Thank you for your help. I'm still having difficulties.
The code you sent me gives an error code -200846.
If anyone knows how to do this with the regular DAQ assistant please chime in
Message 8 of 10
(5,162 Views)
Did you change the channel name to match a real channel you have in your system? Just out of curiosity, have you played around with your device in MAX?
Here is a good article to get you started with DAQ programming as well.
Message 9 of 10
(5,152 Views)
Hi Gregory,
I would like to generate three phase analog voltage signals from NI 9264 with each signals 120 degrees apart. I was trying to use your VI file but couldn't get it done. Please help!
      Phase (deg)
Vline1 Phase A ao0 0
Phase B ao1 120
Phase C ao2 240
Vline2 Phase D ao3 0
Phase E ao4 120
Phase F ao5 240
Cline1 Phase A ao6 0
Phase B ao7 120
Phase C ao8 240
    ao9
    ao10
    ao11
    ao12
    ao13
    ao14
    ao15
Thanks Greg!!!
Message 10 of 10
(2,129 Views)
