Analog Output
Lynn,
That is a cool device.  I had never heard of that before.
Terry
Message 11 of 12
(636 Views)
Terry,
I have not driven one of these from a D/A converter, but I have often done this with op amps. I have built current regulators this way.
These devices are robust: So long as you do not put too much voltage (>35 V) on the inputs or omit the required bypass capacitors, they are nearly impossible to destroy by shorting: They just shut down.  They are also quite inexpensive and readily available.
With an inductive load like the solenoid, some protective diodes are also recommended.
Lynn
Message 12 of 12
(635 Views)
