Analog clock
I have discovered/found an analog clock control and associated VI (they're not mine), but I'm wondering how I can change the spacing of the minor units on the scale so that they display one 'tick' per second, rather than 4 'ticks' for every 5 seconds.
Any ideas?
Edit: I should probably attach the library containing the VI and the control! 🙂
Message Edited by James Mamakos on 07-16-2009 12:33 PM
Never say "Oops." Always say "Ah, interesting!"
(9,567 Views)
Hi James Mam...,
you can open the typedef and ungroup it the gauges. After this you can change the appearance of them.
Mike
(9,539 Views)
Accepted by topic author J.Mamakos
I believe it was my clock you are asking about.
I have added a new blog entry with a new version which addresses the issue you raised.
An Improved Analog Clock
Steve Bird
Culverson.com
LinkedIn
(9,461 Views)
Yes it was, and thank you for the update. Your blog collection is very useful. 🙂
(9,442 Views)
It is possible to set the minor ticks to 1 minute intervals using the “Minor Increment” element of the “Scale.Range” property in the gauges properties node.
See http://tinyurl.com/LV-AnalogClock for more details.
(8,654 Views)
