Analog input connection
Hi....
         I am using NI PXI 6259 Daq card....In this card i have 32 single ended Analog Inputs.....
Can u any one tell what is single ended input and what is differential input..How to wire the Analog inputs in Single ended type and Differential type Methods...
How to convert 4-20 ma into 0-5V... i have one solution..We can put one Parallel resistace acrossthe inpit's...It's Possible or not..i don't know.Please Justify this..and tell me the parallel resistance value which is most suitable....
Sivaramkumar
(3,434 Views)
In this Post, please read the Tutorial Links in the first reply
That should answer your first query
This Post should answer your second Query
(3,430 Views)
Thanks.......
Sivaramkumar
(3,424 Views)
