Analog input from 6210
I repeat 3. time. DID you read my comment on the output signal from your sensor??? 😄 If your sensor outputs current signal, you CANNOT use your DAQ device for measuring it, since it is used for VOLTAGE signals!
Message 11 of 12
(1,114 Views)
Hi seems to be the power supply which gave a lot of noise.
Still a little noise is left.
Tried to replace the sensor with a resistance. That removed the remaining which indicates that the sensor itself produces some noise.
We are reading voltage - by the way and also my calculation was right after all.
Message 12 of 12
(1,095 Views)
