Analog input module 9205 voltage becomes static on crio 9039
Having crio 9039 controller with NI9205 3 nos, NI 9425, NI 9476 and NI 9403 2 nos, My application was running without any issues both
in FPGA and RT , in recent times my analog inputs (9205 module) becomes static and wouldn't respond to any voltage change on the terminals.
Rest of the modules and sequences in FPGA & RT are working without any issues. By switching the power off to the crio controller then my analog inputs are working fine for some period of time then again the same static scenario is repeating.
Message 1 of 8
(1,297 Views)
This looks like the 9205 module is not working properly anymore. Might it have gotten some overvoltage on its inputs at some time that didn't quite destroy it fully but still damage it in some ways?
Rolf Kalbermatter  My Blog
Message 2 of 8
(1,283 Views)
Hi Raj,
This could be a problem in your software or in your hardware.
As we don't have any knowledge about them you need to debug on your own!
Message 3 of 8
(1,280 Views)
I swapped the 9205 module with new one all three still the same effect on the analog inputs.
Message 4 of 8
(1,277 Views)
The software was running well and good for more than 3 years, this problem recently popped up.
I tried with swapping the NI9205 modules but still the same issues. But my other Digital IO modules are working
well and good in FPGA.
Message 5 of 8
(1,274 Views)
Hi Raj,
I tried with swapping the NI9205 modules but still the same issues. But my other Digital IO modules are working well and good in FPGA.
Maybe something changed in your testbench.
We still don't know anything (specific) about your software and hardware!
Message 6 of 8
(1,262 Views)
Hi can i log with you in zoom session to debug your code ?
CLA
Message 7 of 8
(1,253 Views)
Zoom session is not possible
Message 8 of 8
(1,181 Views)
