Analog input subvi's not being recognized in 7.1
Just upgraded to LV 7.1, and I can't find analog input subvi's (ai config, ai read, ai sample channels, etc) when I load vi's. (The vi's were working in LV 7.0.)
(2,743 Views)
Have you installed Nidaq 7.2 ? It comes with LabView 7.1. If you have not, then you need to install it either by down loading it from ni web site, or the CD titled: Device Driver Reference CD)
Normally, if you have chosen full installtion of LabView 7.1, you should have been prompted for the driver CD.
Note: you have to uninstall the existing versions of Nidaq and Max before installing Nidaq 7.2
(2,743 Views)
