Analog inputs,saving to file with USB-6008
HI
I doing a hardware project - I need to measure voltage from 4 analog inputs according to time , sampling every 0,5-1second. I received USB-6008 card and evaluation version of the labview. My problem is that I don't have any experience with this software and now learning whole environment is not my task, it should be only tool to read and save data to the file. I have enough things to do with this project anyway.
I tried some included examples and from the web, it's kind working 1channel and saving to file but I have no control in sampling rate or start,stop button also no time base.
Can anyone help me ? What components should I use?
(3,226 Views)
Post the code you have working so far.
Omar
(3,225 Views)
I started from something like this :  file_1 , saving it's not working
Now I have this : file_2 - readming and saving it's working from 3 channels
But I'm not sure Rate is working, I don't know how to change to infinite samples to read ( tried -1 but not works ),
Also need to add start button and time colum into data file
(3,210 Views)
Try to look on this example. In first frame a simulated waveform is written down into a file. In second frame - it reads a file You have written earlier.
Best regards
Barbara
(3,164 Views)
