Analog output Complex Signal
Wow amazing another super code. I m trying to build those waveform to be able to be analysed on physical oscilloscope  using DAQ to generate the analogue output also I will create a mathematical expression to calculate the area under the curve of the exponential I'm really thankful for your help this is my email send me a message gustavo_dossantos@hotmail.co.uk
I'm sorry I'm not very bright like you I tried to run your code using DAQ and was showing the following error if could have a look will be amazing
thanks lot from London
Message 11 of 14
(943 Views)
As a good starting point (after some tutorials and some DAQmx RTFM 😉 ) is the shipped example
Voltage - Continious Output.vi
(Try to avoid the express vis, they hide too much ...)
replace the the output Array creation for loop with my vi, build a 2D array of dbl from the outputs and change the Anaolg 1d Wfm Nch NSamp  to Analog 2D DBL NChan NSamp
PS: Ask the moderator to remove your email from your post....    and you can use the forum to send private messages 😉
(sometimes I answer them .... )
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 14
(928 Views)
This will sound really stupid  but I did not understand yours step that you said sorry my brain is really slow
thanks a lot
Message 13 of 14
(921 Views)
Hi there thanks a lot for your helping and advice I manage to have those signals output
I would like to say thank to everybody that took a look on my project and NI  for this space to
help others thank you lot
Message 14 of 14
(914 Views)
