Analog outputs of DAQ-6062 card not working properly
I'm using a DAQ-6062 card hooked up to a BNC 2090. The digital I/O works fine, but the analog output (two channels' worth) does not. Under a MAX test panel, the analog output channels display ~1.6V as soon as the test panel opens, and only return to 0V upon reboot.
What's going on? How can I get to an analog output?
(2,885 Views)
Are you looking at the analog output tab of the test panel? The test panel for the analog output should not have a display. Within the analog output test panel, you will only be able to generate a DC voltage or a sine wave. Try connecting an analog output to an analog input. Have the analog output generate a DC voltage in the analog output test panel (make sure to press "update channel" button), and then look at the analog input reading in the analog input test panel. The analog input channel should display the correct DC voltage that you had the analog output generate.
(2,885 Views)
