Analog signal from Laser Power Meter
First, I have to say that I am new using Labview.
Probably for some of you the question I am going to ask is pretty easy, hope you guys can help me solving this.
I am trying to acquire an analog signal from a Fieldmate Laser Power meter, the specifications from this meter are shown in the link below:
http://www.coherent.com/downloads/FieldMateDataSheet.pdf
I need to get the signal and save it in MS Excel files. My big issue is with the acquisition of the signal from the meter to the NI Board. I am using an NI SCB 68.
Hope you guys can help me.
Thanks.
(3,235 Views)
The SCB68 is just a shielded connector block, not a DAQ device.
Use NI's MAX utility (Measurement & Automation Explorer) to find out what DAQ card you have installed in the PC.
There are also plenty of analog acquisition examples that ship with LV, Search Examples in Help.
-AK2DM
(3,228 Views)
I found something:
NI DAQCard - 6024E, is that what we need?
Thanks.
(3,224 Views)
By the way, I am using LabView 8.0.
Thanks.
(3,216 Views)
The 6024 should work fine. The analog ouput update rate of the meter is 20Hz, thus you should set your sampling rate to at leaset 200Hz (samples/second).
There are lots of analog input examples that can be searched under Help in LabVIEW.
-AK2DM
(3,177 Views)
