Analogue Input TTL Synch
I am having trouble triggering an event depending on an analogue input. I am aquiring a sine wave on AI0 as in the attached VI. I would then like to to send a TTL through a digital output or counter timer output if possible (do i use a counter or DO?), depending on a selected phase. For example a would like to send a TTL when the sine wave reached max, min and other phases depending on what phase I select. I would like the ttl to keep on outputing till i stop it. I am having trouble with how to do this!!!
(2,964 Views)
Hi Alloush,
I've made an example which illustrates how this could be done.
Hope it helps!
Pelle S
Account Manager
National Instruments Sweden
(2,950 Views)
HI Pelle,
Thank you for your program it works, I will fiddle with it, and let you know how I get on.
Thank you,
Alloush
(2,943 Views)
