Analyze the MCM PWM signal.
Hello.
I want to analyze the PWM output from the sensor. But this sensor contains 2 signals in one output. Each pulse has a different signal. I want to divide this signal and make 2 PWM outputs.
The picture below is information about the sensor output, and a total of three pulses are repeated. Among them, I want to separate the second and third pulses and make them into respective PWM outputs.
I have to use the FPGA program.
Please Help..
(783 Views)
So, what is the question? Do you need overall guidance to approach the problem or do it for you?
Santhosh
Soliton Technologies
(766 Views)
