Analyzer Test Name Descriptions
Is there a way to retrieve the Descriptions for each of the VI Analyzer Test Names?
I've searched around in the llbs within the vi.lib\addons\analyzer folder but couldn't find a function to do this.
Example: Arrays and Strings in Loops has the description:
Checks loops to see if they contain Build Array or Concatenate Strings functions. Avoid using these functions in loops because each call to them requires a dynamic resizing of the array or string, which can affect memory and processor time.  This test does not check Timed Loops.
Message Edited by Phillip Brooks on 09-30-2008 10:52 AM
(3,038 Views)
Phillip,
There are currently not any VIs that I know of that has this functionality.  The best bet would be to use the Help to get the descriptions.   If you wanted this in a VI, you would probably want to to create an array constant of all the descriptions (manually) and then index them based on the Test Names.
This is definitely a good product suggestion though!
Jared Boothe
Staff Hardware Engineer
(2,995 Views)
Accepted by topic author PhillipBrooks
I looked around a bit more, and discovered that the info I wanted is contained in the VI Description of a VI that matches the name of test test plus "Config.VI". I used VI Server to open the LVLIB that contains these "Config" vis and used "Get All Descendents". I extracted the descriptions that I wanted using VI Server.
See attached VI (LV 8.6)
Message Edited by Phillip Brooks on 10-06-2008 08:47 AM
(2,974 Views)
