09-02-2020 04:29 AM - edited 09-02-2020 05:22 AM
I have installed Andor SDK3 for labview 2020, but when I try to go through provided examples I obtain error "AT Get Int A.vi AOIHeight INVALID HANDLE".
When I set the AOI width and height they just reset to 0 and I get the aforementioned error. Same error pops up when I try other examples
The capture with the example is attached.
I am using Zyla sCMOS 4.2 camera
06-22-2026 03:21 PM
I am having the same issue... has anyone found a solution to this? I am using the Sona 11 with 64bit SDK3 LabVIEW drivers installed and using LabVIEW 2024 64bit. I can connect the camera to Maxim DL 6 and take pictures with it there, however it seems LabVIEW does not want to connect. Any help would be appreciated.
