Anfis
Please I have a question about the ANFIS function in LabVIEW, can anyone help me with that because I want to use it in real-time
with best regards
Hamed Alshareefi
Message 1 of 14
(5,995 Views)
What is the "ANFIS" function?
Message 2 of 14
(5,984 Views)
What is the "question" that you have? Please clarify what you mean by "that":
Do you need help implementing the function? (It has been done before, just search the web).
Do you have the function, but have problems porting it to an RT system?
Message 3 of 14
(5,981 Views)
Adaptive neuro fuzzy inference system
Message 4 of 14
(5,978 Views)
Moderator note: removed link to copyrighted material.
Just... google it... BTW... interesting, I watch you 😉
Best regards, Marcelo.
Message 5 of 14
(5,967 Views)
Thanks, dear for your attention. in fact I googled it a lot ðŸ˜Š. but it's not clear because I want to use the ANFIS in real-time, I don't know where can I build the input membership and the output membership. inside the ANFIS or out its not clear, also the defuzzification,
Message 6 of 14
(5,942 Views)
well... what about have a starting point... put here a .vi ?! Only to see / know for what about we speak. I'm sure that somebody will help you. (is not necessary all project, only a simplified .vi with your problem)
Message 7 of 14
(5,934 Views)
I have the intelligent control toolkit which has the ANFIS but it doesn't work and I don't know how to connect it in real-time spatially there are very little resources about that
Message 8 of 14
(5,888 Views)
Thanks, Marcelo I know the rules that say (people here, help you and but not work instead of you) but believe me I searched a lot about this and I just have specific questions.
1. for the block of ANFIS, where can I configure my input and output memberships.
thanks again
Message 9 of 14
(5,884 Views)
Hi alshareefi,
When you bought that expensive toolkit then you should know it's little distribution among LabVIEW users!
Why don't you ask the company which made that toolkit and so should provide support for their product?
Message 10 of 14
(5,877 Views)
