Animation in DSC-Roller conveyor and motor
Hi all,
I am trying to create an animation for moving conveyor and motor system.Its basically a product handling system. The animation should give a feel that rollers are moving during ON state. For this I have overlapped two belt images (found on Image Navigtor of DSC) and giving then different colours (ON state red colour; OFF state no color).But dont know how to proceed with it.
Any help is appreciated.
Thanks.
 Arihant
(3,185 Views)
I'm not sure why you think that having the two images with the different colors will help you, but there are several ways you can do animation. Here are just a couple:
  1. Create a few images of the belt, one for each frame. Copy them into a picture ring. When the belt is on, run a loop and wire i and N (the number of frames) into a quotient and remainder function. Read the r output and wire it into the picture ring. It will cycle through the frames, creating an animation.
  2. Have a static image of the belt. On top of it place a few "boxes" (maybe booleans). Use the Position.Left property for the controls in a loop to move them, creating animation. If you put all of them inside a cluster, you can then move them past the border of the cluster and back to the beginning without the user seeing it, which will create a smooth effect.
___________________
Try to take over the world!
(3,163 Views)
