Announcing LabVIEW 2010 Service Pack 1
Helmut,
Yes, the localized versions are all availble. Shoot me an email (Jeffrey.Phillips@ni.com) and I can provide you a direct link.
Message 11 of 31
(3,241 Views)
I installed the Service Pack with no apparent difficulties, but now the Distributed System Manager menus are all displaying in an Asian character font!
Everything is still working, but I'd like to get my English menus back... Is there a simple fix?
Kevin Roche
Advisory Engineer/Scientist
Spintronics and Magnetoelectronics group
IBM Research Almaden
Message 12 of 31
(3,082 Views)
I ran a repair on the SP1 and DSC SP1 via the control panel (windows 7x64) and that appears to have solved the font problem.
Kevin Roche
Message 13 of 31
(3,078 Views)
That's a strange one. I'm glad to hear it wsa resolved.
Message 14 of 31
(3,043 Views)
Install process went smooth. Problem is when I try to build a new installer I recieve an error:
Win 7 64bit system. Any thoughts?
Message 15 of 31
(2,978 Views)
Just finished upgrading from 2009 SP1 Dev Suite to  2010 SP1 Dev Suite on Win7 32-bit machine with no problems.  My favorite part was watching the installer default to loading the modules and toolkits I'm licensed to run.  I can't help but cringe thinking about the first time I loaded 7.1 Dev Suite and the stack of CD's it took.  The 2009SP1 install where I had to manually select everything to install.  All the times I've helped co-workers navigate the maze of installing LV.
Message 16 of 31
(2,921 Views)
It happened again, just like before I upgraed to 2010 SP1.
The characters on the front panels changed to chinese or something. I swear I did not want this.
It just happened.
What is going on here?
Scientia est potentia!
Message 17 of 31
(2,877 Views)
It just happened.
This is discussed here - http://forums.ni.com/t5/LabVIEW/Why-does-my-LabVIEW-occasionally-display-in-Chinese/m-p/1495620#M562...
___________________
Try to take over the world!
Message 18 of 31
(2,873 Views)
Regarding the error -30 stuff, check out this document:
http://digital.ni.com/public.nsf/websearch/8E5E6C58C625B88A8625786A005B21E0?OpenDocument
Verne D. // Software R&D // National Instruments
Message 19 of 31
(2,828 Views)
Without arguing the merits of the modern browser to successfully resume intereupted downloads (especially globally), I see your point. Although the intent of the downloader file is to improve the experience of downloading files from ni.com (and has become commonplace), there is no need to "REQUIRE" the downloader file to be used.
Message 20 of 31
(2,795 Views)
