Annoying error
I have a vi  and .llb file which contains the vi and  sub vi s  which are used in the vi . When I run the vi there is the same error for all  3  sub vi s which states
there is no enough memory to compile this vi
and  there is a problem with a subvi but this vi has no block diagram.
 When i double click on this errors the sub vi s block diagram can not be opened. What do u suggest for this kind of problem ?.
(2,920 Views)
Get the source code for the subVIs. It appears that these were saved without the block diagram.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,917 Views)
