Another Excel ActiveX Question
I'm trying to save a 1D array to excel using ActiveX.
When I write 1 value to:
Worksheet Invoke Node -> Range/ Cell string wired to Cell 1
Range Property Node->Value / value wired to Value
It works great. However when I try to write a 1D array by:
Worksheet Inoke Node -> Range/ Beginning Cell string wired to Cell1 - Ending
Cell string wired to Cell2
Range Property Node ->Value/ 1D array wired to Value
What gets saved to excel is the value of the first element in the 1D array
throughout the entire range entered.
I'm using LabVIEW 5.1
Where oh where am I going wrong?
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
Over 80,000 Newsgroups - 16 Different Servers! =-----
(4,446 Views)
I would recomend indexing the 1D array and writing the elements
individually to Excel.
In article <38ddabab_1@news5.newsfeeds.com>,
Ending
array
> Where oh wher
e am I going wrong?
> Thanks
> -----== Over 80,000 Newsgroups - 16 Different Servers! =-----
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,446 Views)
I am already doing that and it is slow. Wiring a 1D array is supposed to be
nearly instantaneous.
wrote in message news:8bnjq0$p9r$1@nnrp1.deja.com...
> Ending
Cell2
> array
> > Thanks
> Before you buy.
(4,446 Views)
You might try the alternative syntax for the Worksheet Invoke
Node->Range method. Instead of wiring a string to both the
Cell1 and Cell2 inputs, wire an A1-style range to Cell1 only.
For example, if you have a 25 element array, wire the string
A1:A25 to cell1. You can pop-up on the Range method to get the
online help for the syntax.
* Sent from RemarQ http://www.remarq.com The Internet's Discussion Network *
The fastest and easiest way to search and participate in Usenet - Free!
(4,446 Views)
I tried that and got the same results. The entire range was filled with the
value of the 1st element of the array.
"MaxMar" wrote in message
news:05265e58.ee335ca2@usw-ex0106-047.remarq.com...
-----= Posted
(4,446 Views)
George:
I just went back and looked at some of my vi's (which I should
have done in the first place). Build your 1D array into a 2D
array and pass that to the Value property node. If you want
columns, transpose the array before passing it. Sorry about the
earlier non-solution.
MaxMar
(4,446 Views)
