Another use for the disable structure (Bug or Feature?)
I always use a lot of dynamic VI's in my projects, and sometimes I need to
pass parameters to them. I use Set Value methods.
One problem is that when you build an executable, the application builder
(AB) removes the panels by default, and the Set Value method will fail... I
know you can change the AB settings, but I was getting tired of that (and
had some free time). I also know you can change the VI properties so AB
won't remove the front panel...
But I started looking for things that tells the AB not to remove the front
panel.
I found out that the FP won't be removed when the VI has an event structure.
And it turns out that this works even if you put the event structure in a
disable case!
I'm pretty sure this isn't supposed to happen. I'm not so sure if it's
usefull since it might change over versions (I use 8.5.1), but I thought I'd
share it anyway...
Wiebe.
(3,029 Views)
You can also just create a property node for one of the controls.
___________________
Try to take over the world!
(3,017 Views)
Just today I had a problem with a VI with a diagram disable structure that would compile but the FP of the executable was mallformed and cause the whole app to crash.
So I stay away from diagram disable structures in execution code.
Ton
My LabVIEW Ideas
(3,006 Views)
"tst" <x@no.email> wrote in message
news:1216732207986-748619@exchange.ni.com...
Sure. But that would actually do something ;)...
You can also add the VI to the list of dynamic VI's. That will also tell the
AB not to remove it's FP. Strange thing is that if you use a static VI
reference, the AB doesn't understand that you are going to use it
dynamically... Seems pretty obvious to me...
Wiebe.
(2,992 Views)
Wiebe,
how do you load the dynamic VI into memory?
If I use the above method I have no issues with FP showing.
Ton (in 8.5.1)
My LabVIEW Ideas
(2,976 Views)
"TonP" <x@no.email> wrote in message
news:1216735809235-748676@exchange.ni.com...
> Wiebe, how do you load the dynamic VI into memory?<img
src="http://forums.lavag.org/uploads//monthly_07_2008/post-2399-1215532702.p
ng"> If I use the above method I have no issues with FP showing.Ton (in
8.5.1)
Almost the same... But I usually don't make my static VI references strictly
typed, because there is no need for that.
I've tested it, and making the static VI reference strictly typed doesn't
make a difference.
I suppose you've added the VI's to the project as dynamic VI's, which makes
it work just fine. But I usually forget that at least one for for a new exe
for each new dynamic vi...
Wiebe.
(2,956 Views)
