Any VI for sampling analog signal?
(2,867 Views)
Hi Sithu,
if you want to use DAQmx, then use the example finder, there are lots of examples in it. If you need something else, then please explain a little bit more.
Mike
(2,863 Views)
To sample a sine wave in labview windows ,  is there any VIs present??
(2,857 Views)
Hi Sithu,
There are numerous examples that come with LabVIEW and LabWindows CVI.  I'm not sure which program you're using, but the method in which to find examples is the same for either program.
To find a voltage, analog input example for the DAQmx driver, go to Tools » Find Examples » Hardware Input and Output » DAQmx » Analog Measurements » Voltage.
I hope this helps,
Kevin S.
(2,837 Views)
