Any attachment to input node makes timed loop unexecutable
T H A N K S !
The ctrl-b worked for me too.  What a relief.
Message 11 of 15
(1,460 Views)
I too had this problem.  I had been developing my vi over several days with no problem connecting a control to the timed loop dt terminal.  Then, I got an error saying that the node was not executable.  I tried control ^ b and the error disappeared and now runs fine again.  Anyone know what control ^ b does?
Message 12 of 15
(1,450 Views)
Ctrl+b removes all "broken" wires on the block diagram.  That's why I made the comment earlier in this thread about the timed loop terminal wiring mechanism being suspect.
Message 13 of 15
(1,447 Views)
Just an update as I see more of you encountering this problem:
This problem is understood and is being addressed - although I can't give more details, I wanted to tell you:
a). that it is indeed being addressed for a future version, and
b). thank you for reporting this so it could be addressed quickly!
Best Regards,
JLS
Best,
JLS
Sixclear
Message 14 of 15
(1,438 Views)
I too am having the same problem.  If ctrl-B doesn't work, I'll be back!
Message 15 of 15
(1,379 Views)
