Any example code to generate and measure both channels using a 4451 DSA card?
I want to generate signals and check the magnitude and phase performance between the inputs on a 4451 DSA card. It seems like there would be some example code already available for this function.
(3,130 Views)
I've attached an example which shows how to perform sychronized input and output with a NI-4451 board. This example only acquires the raw voltages and displays them on a graph. If you want magnitude and phase information, consider using a complex FFT algorithm.
Hope this helps,
Jack Arnold
Application Engineer
(3,130 Views)
Thanks. Is the GenWav(dual).vi a custom VI? Labview can't find it.
Thanks again.
(3,130 Views)
Sorry about that. I forgot I modified that subVI. Here you go.
Jack Arnold
(3,130 Views)
