Any high speed cemera 1000frame/s supported by ni
Any suggestion, thanks.
(2,770 Views)
Basler A504k
if used in full frame (1280*1024) the max frame rate is 500 Hz but if you decrease the nb of lines you can proportionally increase the frame rate.
Ex :
1280*512 -> 1000 Hz
1280*256 -> 2000 Hz
1280*128 -> 4000 Hz
1280*64 -> 8000 Hz
1280*32 -> 16000 Hz
I don't know where it stops, but I've tested up to the 16 kHz and it works fine.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,756 Views)
There are several cameras that can do 1000 fps.  Many require reducing the field of view to get the higher frame rate.  I would check the Graftek site (www.graftek.com) to see what meets your requirements.  Everything they have is LabVIEW compatible.  They are also happy to help you if you call and explain what you need.
Bruce
Bruce Ammons
Ammons Engineering
(2,749 Views)
