Any limitations on the number of USB-6008 I can use on one computer?
I need the temperature rating(55 degrees C) on USB-6008 and 12 channels of plus/minus 20V range(Analog inputs) to operate.
Can I run 3 or more USB devices on one computer?   Has it ever been done before or there is any limitations on this application?
My sampling frequency is going to be 1kHz per channel.
Thanks.
hellolv
Message 1 of 8
(3,145 Views)
i think it wouldn't be a problem, you can connect up to 254 USB devices to a single computer
Message 2 of 8
(3,132 Views)
Well, you might have a problem with the +/-20 volt signals since the USB-6008 has only a +/-10 volt range.
Message 3 of 8
(3,129 Views)
Dennis-
I think the 6008 can do +/-20V in DIFF mode. What college did you go to?wink smiley
-AK2DM
Message 4 of 8
(3,127 Views)
Analog
the USB-6008 says -10v..10v as maximum range for Analog Input in the datasheet
- James
Using LV 2012 on Windows 7 64 bit
Message 5 of 8
(3,121 Views)
Each input is limited to +/-10V from ground in DIFF mode, so:
(-10V) - (10V) = -20V
(10V) - (-10V) = +20V
Thus +/- 20V range. Unless I am totally missing the boat here.happy smiley
I looked up the manual, it tends to agree (portions copied/pasted here):
https://www.ni.com/docs/en-US/bundle/usb-6008-6009-feature/page/introduction.html
The differential input mode can measure ±20 V signals in the ±20 V range.
However, the maximum voltage on any one pin is ±10 V with respect to
GND. For example, if AI 1 is +10 V and AI 5 is –10 V, then the
measurement returned from the device is +20 V.
Input range
Single-ended ................................... ±10 V
Differential...................................... ±20 V, ±10 V, ±5 V, ±4 V,
±2.5 V, ±2 V, ±1.25 V, ±1 V
Working voltage..................................... ±10 V
Message 6 of 8
(3,111 Views)
Kid, you're right. I went by the summary of specifications at https://www.ni.com/en-us/support/model.usb-6008.html. The manual does indeed say that +/-20 is the max for diff mode.
Now, can anyone explain why diff mode supports so many different range settings but with single ended, you are limited to only one?
Message Edited by Dennis Knutson on 03-27-2007 10:39 AM
Message 7 of 8
(3,111 Views)
Sometimes you have to be careful in the quick product overview pages, such as this one that showed negative resistance, capacitance and inductance ranges, I now see it has since been corrected recently:
http://forums.ni.com/ni/board/message?board.id=250&message.id=28786
For the single ended restrictions on the USB-600x, I can only guess it may have an oversight in the programmable gain amplifier programming?
Message 8 of 8
(3,102 Views)
