Any other method to do this (time, miliseconds)?
Hi all,
is there any other more "elegant"(without stringsubset) way to do next thing (I need miliseconds !!!):
_________________________
Rookie; LV 2011 on WIN 7
(2,725 Views)
Cue the Regular Expression heroes.  Unfortunately, I'm not one of them.  That's one thing I need to study up on.
(2,714 Views)
Accepted by topic author hlod
Use the Search/Split String function. Only need 1. Just wire the 10 into the "offset" input.
(2,703 Views)
Well, since you asked. You could use ".*(\.\d+)" as the regular expression.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,677 Views)
Hi hlod,
instead of creating a big string that has to be splitted afterwards you could just create 2 strings:
Quite easy! Elegant too?
(2,670 Views)
