Any possibility to lock part of a diagram?
Is there any possibility to lok part of a function diagram?
The HMI wizard does it. I would like to do the exact same thing : locking a diagram associated to a dedicated indicator, in order, when I suppress the indicator, to suppress at the same time the part of the diagram attached to that indicator.
Thanks for your ideas.
Hélène.
(2,601 Views)
That feature doesn't exist under LabVIEW. Use the indicator context menu
to locate the terminal on the diagram and manually delete the code. If
property nodes, references or local variables are used throughout the
diagram, use the terminal's context menu to list them, locate them and
That's about the cleanest way to do it.
The dirty way is to delete the indicator on the front panel, the list
the errors and patch'em.
oz
>diagram attached
to that indicator.
>Hélène.
(2,601 Views)
