Any simple method to detect noise level of a wave
Since the sampling rate is 100M, one pulse may still have 100 point, unless put median window quite big, then will make it quite slow.
Message 11 of 14
(590 Views)
Never mind, I can detect the noise level, then scan the original signal again to extract the pulse.
Message 12 of 14
(588 Views)
Still not find a way yet 😞
Message 13 of 14
(569 Views)
Please post your VI with some typical data saved as default.  Guessing from looking at a picture is not getting anywhere.  If we have some real data to play with, perhaps someone will come up with a way to do what you want.  Be sure to indicate which "peaks" in the data set are real signals.
Lynn
Message 14 of 14
(558 Views)
